ERROR
The Report could not be generated with the current settings. Edit the report in the Report Designer and try again
Error Message
This error may occur when working with the Create Report option in ArcMap. The full error message is provided below.
[O-Image]
Cause
The error may occur when selecting to sort the inputs from the selected report source, such as an Excel spreadsheet, if it does not contain an ObjectID field.
[O-Image]
Solution or Workaround
If the report requires the data to be sorted, the input data source must contain an ObjectID field. To add an ObjectID field, convert the input table to an ArcGIS format.
The table can be converted to an ArcGIS format using the Table to Table geoprocessing tool in Conversion Tools > To Geodatabase or the Excel to Table tool in Conversion Tools > Excel.
Article ID:000011946
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
