ERROR
The print service URL you have entered is invalid or inaccessible
Last Published: November 7, 2023
Error Message
Attempts to configure a print service in Portal for ArcGIS fail with the following error message returned:
Error:
The print service URL you have entered is invalid or inaccessible.
The error message returned when configuring a print service
Cause
  • The print service is not running in ArcGIS Server Manager.
  • An incorrect print service URL is used when configuring a print service in Portal for ArcGIS.
Solution or Workaround
Start the printing service in ArcGIS Server Manager
  1. Navigate to ArcGIS Server Manager and login as an administrator.
  2. Click Services > Manage Services > Utilities.
  3. Identify the print service, and click the Start button.
Stopping and starting the print service in ArcGIS Server Manager
Alternatively, restart the print service if the service is running. Click the Stop button. After the service is stopped, click the Start button.
Use the correct print service URL
Ensure the correct is used when configuring a print service in Portal for ArcGIS. Refer to Portal for ArcGIS: Printing for more information on the correct URL format for the default or custom print service.
Article ID: 000031465
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise 11 0
  • ArcGIS Enterprise 11 1
  • ArcGIS Enterprise 11 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
