ERROR
The print service URL you have entered is configured for Asynchronous execution. A print service configured for Synchronous execution is required
First Published: October 4, 2023
Last Published: October 4, 2023
Error Message
Attempts to add a print service in Portal for ArcGIS fail with the following error message returned:
Error:
The print service URL you have entered is configured for Asynchronous execution. A print service configured for Synchronous execution is required.
The error message returned when attempting to add a print service in Portal for ArcGIS
Cause
The print service is configured or published as an asynchronous service.
Solution or Workaround
Set the Execution Mode parameter of the print service to Synchronous in ArcGIS Server Manager
  1. Open ArcGIS Server Manager and log in with an administrator account.
  2. Click Services > Manage Services. Browse to and click the custom print service.
  3. Click Parameters and select Synchronous under the Execution Mode parameter.
  4. Click Save.
The Synchronous setting in ArcGIS Server Manager
Publish a print service from ArcGIS Pro with the Execution Mode set to Synchronous
To prevent this error from returning when creating a new print service in ArcGIS Pro, set the Execution Mode to Synchronous before publishing the print service to ArcGIS Enterprise. Refer to ArcGIS Enterprise: Share a printing web tool to the ArcGIS Enterprise portal for instructions.
Article ID: 000031271
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
