ERROR
The number of user types assigned exceeds the number of user types available. Go to the Licenses tab for more details
Last Published: January 13, 2025
Error Message
Logging in to Portal for ArcGIS returns the following error:
Error:
The number of user types assigned exceeds the number of user types available. Go to the Licenses tab for more details.
The error message, The number of user types assigned exceeds the number of user types available. Go to the Licenses tab for more details. is returned.
Cause
  • The license of the existing user type has expired. The expiration date of the user type is found in the Portal Administrator Directory License page.
The expiration date of the user type in the ArcGIS Portal Administrator.
  • The organization is utilizing a new license no longer containing the user type previously assigned to the portal members.
Solution or Workaround
Import a new portal license file in the portal
  1. Create a new portal license file in the organization's My Esri with valid, non-expired user types. Refer to ArcGIS Enterprise: Obtain a portal license file for further instructions.
  2. Import the new portal license file in Portal for ArcGIS. Refer to Portal for ArcGIS: Import licenses for more information.
If the organization utilizes ArcGIS Pro, configure the ArcGIS Pro named user license to log in to ArcGIS Pro with the new license. Refer to Portal for ArcGIS: Configure ArcGIS Pro licenses for your organization for further instructions.
Reassign the member with a valid user type
Change the user type of the member with a user type assigned to the license. Refer to Portal for ArcGIS: Change user types for further instructions.
Article ID: 000027800
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
