ERROR
This error occurs when performing one of the following spatial operations between datasets originating from SAP HANA 2 SPS3 when the datasets are in different spatial references and one of the datasets is in SAP HANA’s WGS 84 planar spatial reference (HANA SRS_ID=1000004326):
SAP HANA 2 SPS3 includes an incorrect SRS definition for it’s WGS 84 planar spatial reference (SRS 1000004326). See SAP HANA issue 210783 for more information.
A DBA needs to fix the faulty WGS 84 planar spatial reference by following this SAP-provided procedure:
DROP SPATIAL REFERENCE SYSTEM "WGS 84 (planar)";
CREATE SPATIAL REFERENCE SYSTEM "WGS 84 (planar)" IDENTIFIED BY 1000004326 DEFINITION 'GEOGCS["WGS 84" DATUM["WGS_1984" SPHEROID["WGS 84" 6378137 298.2572236 AUTHORITY["EPSG" 7030]] AUTHORITY["EPSG" 6326]] PRIMEM["Greenwich" 0 AUTHORITY["EPSG" 8901]] UNIT["degree" 0.017453293 AUTHORITY["EPSG" 9122]] AUTHORITY["EPSG" 4326]]' ORGANIZATION "EPSG" IDENTIFIED BY 4326 TRANSFORM DEFINITION '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs' LINEAR UNIT OF MEASURE "planar degree" ANGULAR UNIT OF MEASURE "degree" TYPE PLANAR COORDINATE LONGITUDE BETWEEN -180 AND 180 COORDINATE LATITUDE BETWEEN -90 AND 90 TOLERANCE DEFAULT SNAP TO GRID DEFAULT POLYGON FORMAT 'EvenOdd' STORAGE FORMAT 'Internal';
Article ID: 000020719
Get help from ArcGIS experts
Download the Esri Support App
