ERROR
The geometry for a turn cannot start or end at a junction
Error Message
**Internal Publish Only! This article may contain information that is not intended for external circulation.**While trying to create a new turn feature, the following error message is displayed:"The geometry for a turn cannot start or end at a junction."
Cause
The turn editor is mistakenly using the spatial reference's tolerance setting, which is in map units, to determine the closeness of a edit sketch to a junction.
For example, if the tolerance is 0.2 feet, then anything between 0%-20% or 80%-100% along the edge is considered too close to the junction.
Solution or Workaround
For the example tolerance of 0.2 feet, click between 20%-80% along the edge.
    Article ID:000008928
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
