ERROR
The FUSE sub-system is either not installed or not running
First Published: October 15, 2019
Last Published: July 29, 2025
Error Message
After installing ArcGIS License Manager 2019.0, running the install_fnp.sh shell script on a Linux operating system as either a root or sudo user returns the following error:
Error:
ERROR: The FUSE sub-system is either not installed or not running
Cause
As of FNP service 11.4.1.1, the FUSE component has changed from depending on Activation Secure File Anchors to the FNP Licensing Service Daemon. This daemon requires the FUSE sub-system to be installed and running on the host machine which is checked by the install_fnp.sh shell script.
If a minimal installation of Red Hat Enterprise Linux (RHEL) or SUSE Linux Enterprise (SLES) is performed, the required packages for the FUSE sub-system are not installed.
Solution or Workaround
For Red Hat Enterprise Linux systems (including CentOS and SUSE), install the gvfs-fuse package and any dependencies from the package manager of the operating system. Refer to Flexera: Why is FUSE required with FNP 11.14.1.1 install_fnp.sh on Linux? for more information.
After the gvfs-fuse package is installed, rerun install_fnp.sh as a root or sudo user.
Article ID: 000022140
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
