ERROR
The Field type is invalid or unsupported for the operation.
Error Message
Using the 'Feature Class to Feature Class' tool in ArcGIS Desktop 9.2 to export a dataset containing a GlobalID field to a shapefile returns the following error message:
"The Field type is invalid or unsupported for the operation.[GlobalID]"
Cause
Shapefiles do not support the Global ID field type; therefore, it is not possible to export this field type to a shapefile.
Solution or Workaround
The 'Feature Class to Feature Class' tool contains an optional 'Field Map' parameter that allows fields in the output dataset to be added, renamed, deleted or modified. Since the shapefile does not support the GlobalID field, the Field Map parameter can be used to delete the GlobalID field from the output shapefile.
  1. Initialize the 'Feature Class to Feature Class' tool and specify the input dataset. This will populate the Field Map parameter with all the fields in the input feature class.
  2. Select the GlobalID field and click the delete button on the right.
    [O-Image] delete button
  3. Click OK to run the tool. The GlobalID field will be deleted.
Article ID: 000010247
Software:
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
