ERROR
The Field type is invalid or unsupported for the operation
Error Message
When exporting data to dBase or a shapefile, the following error occurs in ArcMap:
"The Field type is invalid or unsupported for the operation."
This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Cause
The table or layer contains a BLOBĀ field.
Solution or Workaround
  1. Right-click the layer in ArcMap and open the Layer Properties dialog box.
  2. Click the Fields tab.
  3. Select the Blob field and make sure the Visible check box is not checked.
[O-Image] layer properties - fields tab
Article ID:000003698
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
