ERROR
Building new ArcObjects SDK for .NET Projects from application project templates returns the following error:
“The extension was not able to find the startup entry point for the project.”
This error occurs only with Visual Studio 2019 when a new project is created using one of the following project templates:
After selecting the license to be checked at startup from the Project Template wizard, Visual Studio 2019 displays the following error messages:
All Application Project Templates use a Visual Studio project template wizard code-behind to insert custom code snippets into the newly created project, for example, the license-checking code. The cause of the problem is that Visual Studio 2019 is passing a bad (or corrupt) EnvDTE.Project object to one of the project template’s call back functions. When trying to use the EnvDTE.Project parameter, the error is thrown. Usually the problem doesn’t occur when creating a new project at startup of Visual Studio 2019, but the project creation consistently fails when project creation is attempted from within an open VS 2019 instance.
To create a new project, you can either try to restart Visual Studio 2019 and try to create a new project at startup, or you can manually update your project’s license startup code as follows:
using ESRI.ArcGIS.esriSystem;
private static LicenseInitializer m_AOLicenseInitializer = new DesktopConsoleApplication4.LicenseInitializer();
// ESRI License Initializer generated code.
m_AOLicenseInitializer.InitializeApplication(new esriLicenseProductCode[] { esriLicenseProductCode.esriLicenseProductCodeBasic },
new esriLicenseExtensionCode[] { });
// Do not make any call to ArcObjects after ShutDownApplication()
m_AOLicenseInitializer.ShutdownApplication();
Article ID: 000022152
Get help from ArcGIS experts
Start chatting now
