ERROR
The changes you requested to the table were not successful because they would create duplicate values in the index, primary key or relationship
Error Message
When performing any of these tasks:
- Copy/Paste in ArcCatalog.
- Start editing within ArcMap.
- Editing features in a geodatabase through the ArcMap Editor.
- Adding an index to a field.
A variation on the following error message is raised:
"The changes you requested to the table were not successful because they would create duplicate values in the index, primary key or relationship. Change the data in the field or fields that contain duplicate data, remove the index or redefine the index to permit duplicate entires and try again."
Cause
As the message indicates, there are duplicate values in an index, primary key or relationship in a table or feature class.
Solution or Workaround
In order to resolve this issue, identify the duplicate values and correct them. Determining the duplicate values can be done any number of ways:
- Within ArcMap using the Table Window.
- Through SQL.
- Within ArcCatalog using the Statistic command in Table preview window.
If the error is encountered during Copy\Paste or Start Editing, it may be due to any one of the reasons listed below. Other scenarios where the error is raised may be corrected through one of the following solutions:
  1. The error may be due to a user-generated unique index. Confirm that no such indexes exist. If they do, delete the index before proceeding.
  2. If the error is generated while adding an index to a field, confirm that the field in question does not have any duplicate values. If it does, they need to be removed before the index can be added.
  3. If the error is raised during editing, the issue describe in the following knowledge base article may be what is being encountered:
    Article 23687 - Error: The changes you requested to the table were not successful
    Follow the steps in article 23687 to resolve the issue.
Article ID:000006492
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
