ERROR
The authorization file selected is for the 9.0 version of ArcView. Please select the correct 9.2 authorization file
Error Message
When registering ArcView or ArcEditor single use, or registering a single use ArcGIS Desktop extension, the following error message displays:"The authorization file selected is for the <version_number> version of ArcView. Please select the correct <version_number> authorization file."
Cause
The authorization file is for a different version of the software than the version installed.
Solution or Workaround
  • Request an ESRI Authorization file for the version of ArcGIS Desktop installed at http://service.esri.com.
    The single use registration or UNK number must have already been required.
  • To request a single use registration or UNK number, contact Esri Customer Service.
Article ID:000009121
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
