ERROR
The account could not be used to sign in because you have exceeded the maximum number of allowed sessions
Last Published: December 2, 2021
Error Message
When attempting to log in to ArcGIS Pro with an ArcGIS Online account, the following error message is returned:
Error:
The account could not be used to sign in because you have exceeded the maximum number of allowed sessions.
Logging in to ArcGIS Pro fails and an error message is returned.
Cause
The ArcGIS Online account has been used to log in to ArcGIS Pro on three different machines at the same time, and the maximum number of allowed active ArcGIS Pro sessions is three.
Solution or Workaround
Use one of the following options to resolve this issue.
Ensure the ArcGIS Online account is not used on more than three machines at the same time
In some instances, administrators must unassign and reassign the member’s ArcGIS Pro add-on license. Refer to ArcGIS Pro: Assign or unassign an ArcGIS Pro add-on license or extension for more information.
If the methods described above fail, run the repair on ArcGIS Pro.
  1. On the machine wherein ArcGIS Pro is installed, navigate to Control Panel > Programs > Programs and Features.
  2. Browse to and right-click ArcGIS Pro. Select Change.
  3. Click Yes when prompted, and click Repair > Next.
Run the ArcGIS Pro installer to repair it.
  1. Click Install. Once the repair is complete, click Finish.
Article ID: 000026878
Software:
  • ArcGIS Online
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
