ERROR
STOP: 0x000000CE (0x....) parport.sys
Error Message
After undocking a laptop from the docking station, plugging in a parallel hardware key and running any function that calls said hardware key, a STOP error occurs. Windows STOP errors are commonly refered to as the Blue Screen of Death or BSoD."A problem has been detected and Windows has been shut down to prevent damage to your computer.The problem seems to be caused by the following file: parport.sysDRIVER_UNLOADED_WITHOUT_CANCELLING_PENDING_OPERATIONS"
Cause
While starting a laptop that is docked, a specific hardware profile is established, and the Sentinel driver is configured for that profile. When the laptop is undocked, the machine should use a second hardware profile, but the driver continues to assume the first profile, so a call to that driver causes it to crash.
Solution or Workaround
To avoid this error there are two options:
  • Instead of using the undock option, shut down the laptop when undocking it from the docking station and restart it, allowing the sentinel driver to initialize during the boot sequence.
  • After undocking, go to C:\Program Files\Rainbow Technologies\Sentinel System Driver\SetupSysDriver.exe. Launch the executable and click Stop NT parallel driver. Click Start NT parallel driver. Stop and restart the License Manager service, if necessary.
Article ID:000006662
Software:
  • ArcMap 8 x
  • ArcMap 9 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
