ERROR
st_numgeometries in Oracle encounters the error ORA-29900: operator binding does not exist
Error Message
Attempting to pass an ST_Geometry attribute that is not an st_geometrycollection (multi-part feature) encounters the following Oracle error:
"SELECT sde.st_numgeometries(shape) FROM zipcodes
ERROR at line 1:
ORA-06553: PLS-306: wrong number or types of arguments in call to
'ST_NUMGEOMETRIES'"
Cause
The error is encountered when an ST_Geometry attribute of st_point, st_linestring or st_polygon is passed to the sde.st_numgeometries operator. The st_numgeometries operator argument requires the input geometry to be a collection, which is an sde.st_geometrycollection type defined as either st_multipoint, st_multilinestring or st_multipolygon.
The following example demonstrates using st_numgeometries with a table named zipcodes which contains both st_polgyon and st_multipolygon geometries. In the example, where the multi-part polygon is passed to the operator, no error is encountered and the number of parts for the input geometry is returned. When passing a polygon to the operator, the error is encountered.
Code:
SQL> CREATE TABLE zipcodes
2 (postal_code NUMBER,
3 shape sde.st_geometry);
Table created.
SQL> INSERT INTO zipcodes VALUES
2 (45208, st_geometry('multipolygon (((10 10, 10 50, 50 50, 50 10, 10 10),
3 (60 60, 60 70, 70 70, 70 60, 60 60)))', 1));
1 row created.
SQL> SELECT sde.st_numgeometries(shape)
2 FROM zipcodes
3 WHERE postal_code = 45208;
SDE.ST_NUMGEOMETRIES(SHAPE)
2 (92373, st_geometry('polygon ((1 1, 1 5, 5 5, 5 1, 1 1))', 1));
1 row created.
2 FROM zipcodes
3 WHERE postal_code = 92373;
SELECT sde.st_numgeometries(shape) FROM zipcodes WHERE postal_code = 92373
ERROR at line 1:
'ST_NUMGEOMETRIES'
Solution or Workaround
Do not attempt to pass an ST_Geometry attribute to the operator that is not of type st_multipoint, st_multilinestring or st_multipolygon.
    Article ID:000009806
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
