ERROR
Segmentation fault when starting ArcIMS Administrator
Error Message
When issuing the aimsadmin command, the following error is yielded:....../bin/aimsadmin: line 87: 2346 Segmentation fault $JAVA_HOME/bin/java $Options -cp $JARHOME/jaxp.jar:$JARHOME/parser.jar:$JARHOME/esri_mo10.jar:$JARHOME/esri_mo10res.jar:$JARHOME/arcims_aej.jar:$JARHOME/arcims_admincore.jar:$JARHOME/arcims_admin.jar:$JARHOME/arcims_designer.jar:$JARHOME/jcert.jar:$JARHOME/jnet.jar:$JARHOME/jsse.jar:$JARHOME/arcims_resadmin.jar com.esri.aims.admin.console.AdminMain
Cause
The presence of an LD_ASSUME_KERNEL environment variable can cause this problem. You can check for the existence of this variable in a C shell environment by using the env command:
>>env
LD_ASSUME_KERNEL=2.2.5
Usually this variable is used during the installation of Oracle.
Solution or Workaround
Unset the LD_ASSUME_KERNEL variable before running standalone administrator. For example, in the C shell environment:
>>unset LD_ASSUME_KERNEL
>>aimsadmin
    Article ID:000005805
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
