ERROR
Segmentation fault
Error Message
When installing using the 'install -load' command after entering the mount point of the CD-ROM, Linux returns the following error:Segmentation fault
Cause
The default option for the mount point is /cdrom but the ArcIMS and ArcExplorer installations require the mount point to also include the appropriate directory on the CD-ROM.
Solution or Workaround
Append the command /mnt/cdrom with the appropriate product directory.
ArcIMS 4.0:
Code:
/mnt/cdrom/ArcIMS4.0
ArcExplorer 4.0:
Code:
/mnt/cdrom/ArcExplorer4.0
Article ID:000005347
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
