ERROR
sdeimport -o create" generates SDE Code (-20): Layer not found
Error Message
"sdeimport -o create" generates the following error message:
ESRI SDE SDEX File Import Utility Fri Dec 1 06:13:32 2000
Import SDEX from tx_block.sdx
Unable to get layer information.
Error in creating SDE layer.
0 features read.
0 features stored.
Cause
There is insufficient space for the initial extent to be allocated in the tablespace.
Solution or Workaround
Add more space to the tablespace.
Add a new database file to a specific tablespace:
ALTER TABLESPACE "tablespace_name" ADD DATAFILE 'D:\ORACLE\ORADATA\ORC1\dbf013.ora' SIZE 10M AUTOEXTEND ON NEXT 2M MAXSIZE UNLIMITED
Or
Alter an existing tablespace parameter:
ALTER TABLESPACE "tablespace_name" DEFAULT STORAGE (INITIAL 128K NEXT 128K MINEXTENTS 2 MAXEXTENTS UNLIMITED PCTINCREASE 1);
ALTER DATABASE DATAFILE 'D:\ORACLE\ORADATA\ORC1\dbf01.ORA' RESIZE 30M;
ALTER TABLESPACE "tablespace_name" MINIMUM EXTENT 1K
Article ID:000002489
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
