ERROR
SDE not running on server, Unable to get rqmgr status
Error Message
Issuing a GPMON command produces:
SDE not running on server, Unable to get rqmgr status.
Cause
GPMON is used to start both the ArcSDE and the gpserver instances. If the ArcSDE instance and the gpserver instance names match, an error will be returned.
Solution or Workaround
Navigate to C:\arcgis\arcexe81\gpserver and change the instance name and port number of the gpserver instance in the services.rqm file.
Navigate to C:\WINNT\SYSTEM32\DRIVERS\ETC and change the instance name and port number of the gpserver instance in the services file.
Article ID:000002476
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
