ERROR
SDE for Informix: SQLAllocEnv: referenced symbol not found
Error Message
After installing SDE, trying to start the SDE server produces this error:
ESRI SDE I/O Manager - Version 3.0.2.2 Fri Dec 31
06:36:10 PST 1999
ld.so.1: /opt/esri/sdeexe302/bin/giomgr: fatal:
relocation error: file /opt/esri/sdeexe302/lib/libsdesrvr.so: symbol
License Service: communication read error!LO_read_long: Error 0
License service exiting.
Could not start SDE -- Check Network, $SDEHOME disk and DBMS.
Cause
ODBC is used to connect from SDE to Informix. SQLAllocEnv is the first ODBC-related module called from the ClientSDK. SDE 3.x for Informix requires the use of Informix ClientSDK version 2.10. When another version of the ClientSDK is used, this module cannot be loaded.
Solution or Workaround
Install Informix ClientSDK version 2.10. Please see related document for instructions on acquiring and installing this product.
Article ID:000001969
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
