ERROR
Run-time error '61704': Internal application error.
Error Message
When executing an AddRelate in a MapObjects application, the following error may occur:Run-time error '61704': Internal application error.
Cause
This error is caused by the Database or Name property of the Table object not being set correctly.
Solution or Workaround
  • Make sure the string passed to the Database property on the Table object contains the correct path to the database file.
  • Check the syntax of the string passed to the Table.Database property.
    Using Jet syntax for an MS-Access table:
    Code:
    tbl.Database = "c:\mapdata\Streets.mdb" 'MS-Access
    tbl.Name = "Stplus" 'Access Table
    Using DAO syntax for a dBase (version 4) table:
    Code:
    tbl.Database = "dBASE IV;DATABASE=C:\mapdata\"
    tbl.Name = "streets#dbf"
    Warning:
    The dBase filename must conform to the 8.3 file naming convention.
  • Check the permissions on the database file. If the file permissions are set to Read-Only for the users attempting to AddRelate the file, the error will occur. Change the file permissions to Read-Write (or equivalent) for the users who will be accessing the file using AddRelate.
Article ID:000002219
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
