ERROR
Run-time error '5': Invalid procedure call or argument
Error Message
When using the Coverage to Shapefile tool, changing the 'INFO item' in the 'Field definition' frame causes the following error:
ATConv
Run-time error '5':
Cause
The feature attribute table for the coverage is selected in the ArcInfo Workstation TABLES module. The file is read-locked and the tool cannot get a list of the items from the attribute table.
Solution or Workaround
Do one of the following:
  • Unselect the attribute table in the ArcInfo Workstation TABLES module.
  • Close the ArcInfo Workstation TABLES module entirely.
Article ID:000003766
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
