ERROR
Run Time Error: Automation error. Unspecified error.
Error Message
Using the Select method on an IFeatureClass object causes a runtime error. For example, the following line would cause an error:
Set theSelection = pFeatureClass.Select(pQueryFilter, esriSelectionTypeIDSet, esriSelectionOptionNormal, pFeatureWorkspace)
Cause
This is a known issue.
Solution or Workaround
This issue has been resolved for ArcGIS 8.1 and above.
Article ID:000002546
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
