ERROR
Requested operation could not be completed
First Published: February 2, 2023
Last Published: February 21, 2023
Error Message
In ArcGIS Pro, attempts to apply, change, rename, or reorder symbology in the Symbology pane may fail, and return the following generic error message:
Error:
Requested operation could not be completed.
The error message in the Symbology pane,
Although this message seems generic, it only occurs in the Symbology pane, and is specific to ArcGIS Pro symbology workflows.
Cause
There is a variety of situations that may cause this issue, among these are:
  • Edits made on the feature classes are not saved properly before applying symbology.
  • Feature classes are stored in an enterprise geodatabase instead of a file geodatabase.
  • There are null values in the field.
  • Symbology is applied to feature layers with a temporary join.
  • Using the earlier version of ArcGIS Pro.
Solution or Workaround
The simplest solution is to close and re-open the Symbology pane. However if this does not resolve the issue, use one of the options described below, depending on the cause.
If the issue persists, contact Esri Technical Support.
Article ID: 000029255
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
