ERROR
Request error 403 Request not made over ssl
First Published: March 2, 2021
Last Published: April 27, 2022
Error Message
Attempts to publish surveys from ArcGIS Survey123 Connect fail, and return the following error message:
Error:
Cause
This error occurs when an HTTP URL is used in the submission URL of the XLS form in the survey. ArcGIS Online enforces the HTTPS Only default setting and no longer supports HTTP. Refer to Important Updates for ArcGIS and HTTPS Only Enforcement for more information.
Solution or Workaround
If the feature service is not available in HTTPS, the address cannot be used in the submission URL of the XLS form..
On the Settings tab of the XLS form of the survey, change the submission URL from HTTP to HTTPS in the submission_url column.
Using HTTPS in the address for the submission URL.
The following image demonstrates the survey is published successfully.
A survey is published successfully from ArcGIS Survey123 Connect.
Article ID: 000025220
Software:
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
