ERROR
RegCat Run-time error '-2147024770 (8007007e)': Automation error: The specified module could not be found
Error Message
When installing ArcGIS Desktop, the following error is received:
"RegCat
Automation error
The specified module could not be found."
Cause
This error is caused by a problem with the Microsoft Script Runtime Library.
Solution or Workaround
Manually register the Microsoft Script Runtime Library by following these steps:
  1. Click Start > Run.
  2. Type cmd and click OK.
  3. Type the following and press Enter:
regsvr32 "c:\windows\system32\scrrun.dll"
  1. Close out of the Command Prompt: type exit, and press Enter.
  2. Restart the ArcGIS Desktop installation.
Article ID:000009949
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
