ERROR
Record(s) cannot be read; no read permissions on 'Globals'.
Error Message
This error occurs when starting ArcLogistics Route:"ArcLogistics Route has encountered an unexpected error (3112 - Application defined or object-defined error) in module cVRPWorkspace.cls, Function ReadDataVersion, line 20. Record(s) cannot be read;no read permission on 'Globals'. While you may be able to continue and save your work, you should restart ArcLogistics Route."
Cause
Occasionally, when closing a session of ArcLogistics Route, the compacting of alr.mdb fails and creates a corrupted file.
Solution or Workaround
Delete the corrupted alr.mdb file.
  1. Use Windows Explorer to navigate to the ArcLogistics Route folder. By default it will be located at
    C:\Program Files\ESRI\ArcLogistics Route.
  2. Open the ArcLogistics Route folder and look for the MapData_xxx folder you are working with.
  3. Open the MapData_xxx folder and look for the file alr.mdb.bak.
  4. Make a copy of the alr.mdb.bak file.
  5. Locate the alr.mdb file in the same folder.
  6. Delete the alr.mdf file.
  7. Rename the alr.mdb.bak to alr.mdb.
    ArcLogistics Route should start without an error.
Article ID:000004057
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
