ERROR
<Portal URL> did not successfully connect. Enter a valid connection URL on the backstage
Last Published: July 21, 2020
Error Message
Attempting to log in to ArcGIS Maps for Office in Microsoft Excel returns the following error message:
Error:
<Portal URL> did not successfully connect. Enter a valid connection URL on the backstage.
Cause
The following are possible causes for the error:
Solution or Workaround
Move the ArcGIS Maps for Office path variable to the top of the Path variable value list in the system variables of the machine, and add an ArcGIS Connection using a valid portal URL.
  1. Click the Start button and type in 'Advanced System Settings' to search.
  2. Click View advanced system settings to open the System Properties window.
  3. On the Advanced tab, click Environment Variables....
Image of the System Properties window
  1. Under the System variables section, double-click the Path variable to edit the system variables.
  2. For Variable value, move the following variable to the top of the variable value list:
C:\Program Files (x86)\ArcGISMaps\Office
  1. Click OK to close the Environment Variables window.
  2. Click OK to close the System Properties window.
  3. In Microsoft Excel, click File and navigate to ArcGIS Maps.
  4. Add a connection to ArcGIS Online or ArcGIS Enterprise using a valid URL.
For ArcGIS Online
https://<organizationShortName>.maps.arcgis.com
For ArcGIS Enterprise
https://<gisserver>.<domain>.com/portal
  1. Restart ArcGIS Maps for Office.
Article ID: 000023396
Software:
  • ArcGIS for Office 4 0
  • ArcGIS Online
  • ArcGIS for Office 5 0
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
