ERROR
Portal for ArcGIS: You do not have permissions to access this resource
First Published: January 25, 2021
Last Published: April 25, 2024
Error Message
When an administrator attempts to delete an organization member in Portal for ArcGIS, the following error message is returned:
Error:
You do not have permissions to access this resource.
The error message returned when attempting to delete a member in Portal for ArcGIS
Cause
The user counts in the portal's index and the database store do not match. This causes Portal for ArcGIS to not recognize the organization member.
To review the store and index counts, refer to Steps 1 through 3 in the following documentation: ArcGIS Enterprise: After upgrading, I don't see all of my items, groups, and users in my portal. What's going on?
Solution or Workaround
Apply the steps provided below to resolve the issue.
  1. Log in to the Portal Administrator Directory as an administrator using the following URL:
https://<webadaptorhost>.<domain>.com/<webadaptorname>/portaladmin
  1. On the Home page, for Resources, click System > Indexer.
  2. For Supported Operations, click Reindex.
The Reindex option in the Portal Administrator Directory
  1. Click the Mode drop-down list and select User.
  2. Click Reindex.
The Mode drop-down list and the Reindex button in the Portal Administrator Directory
Article ID: 000025055
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
