ERROR
Portal for ArcGIS: Failed to start the database server. The startup timed out
First Published: February 24, 2026
Last Published: July 2, 2026
Error Message
When upgrading Portal for ArcGIS, the upgrade process fails and returns the following error message:
Error:
Failed to start the database server. The startup timed out. Please check the log file at D:\arcgisportal\logs\database\pgsql.log.
The error message
Cause
The machine hosting Portal does not have sufficient disk space available for the upgrade to be completed.
Solution or Workaround
Free up disk space on the machine to ensure that a minimum of 2.5 times the space allocated to the Portal content, index, database, and temporary directories is available. Refer to ArcGIS Enterprise on Windows and Linux: Prepare to upgrade for more information. The options below are applicable before upgrading Portal:
Article ID: 000040444
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
