ERROR
When using ArcGIS for AutoCAD with AutoCAD Plant 3D Collaboration projects, the process presents an error if ArcGIS for AutoCAD is installed:
"Please Install the latest update of AutoCAD Plant 3D 2022 to work with Collaboration for AutoCAD Plant 3D".
ArcGIS for AutoCAD and AutoCAD Plant 3D both use the same dependency, Newtonsoft's Json.NET. Collisions occur when one of the programs tries to use Newtonsoft's Json.NET. Only one version of a dependency may be present to ensure no collisions occur.
The following steps are an example of the workflow that returns the error:
Remove the copy of Newtonsoft's JSON.Net from the ArcGIS for AutoCAD Install directory:
Note: This procedure requires administrator access.
C:\Program Files\Autodesk\ApplicationPlugins\ArcGISForAutoCAD.Bundle\Contents
Article ID: 000027365
Get help from ArcGIS experts
Start chatting now
