ERROR
Please ensure you have a publisher or admin connection to standalone server
First Published: January 9, 2024
Last Published: January 9, 2024
Error Message
When attempting to publish a map service from ArcGIS Pro to ArcGIS Server, the following error message is returned:
Error:
Please ensure you have a publisher or admin connection to standalone server.
The error message "please ensure you have publisher or admin connection to standalone server" returned when publishing a map service
Cause
  • The ArcGIS Server credentials used when adding an ArcGIS Server connection does not have the Administrator or Publisher server roles when publishing the web service.
  • If the account does meet the role requirements, the connection type in the ArcGIS Server Connection Properties window is set to User Connection instead of Publisher Connection or Administrator Connection.
Solution or Workaround
Acquire the appropriate roles and privileges
In ArcGIS Server Manager, create and assign the Administrator or Publisher roles to the user account in the ArcGIS Server built-in store before attempting to publish a web service. Refer to ArcGIS Server: Add roles and ArcGIS Server: Manage users in Manager for instructions.
Set the connection type to Administrator or Publisher in ArcGIS Pro
Refer to ArcGIS Pro: View and modify server connection properties for instructions. In Step 2, change the connection type to Publisher Connection or Administrator Connection from the drop-down menu.
Article ID: 000031700
Software:
  • ArcGIS Pro
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
