ERROR
Permission Denied
Error Message
When users try to view an HTML Viewer web site, they get this JavaScript error:
Permission Denied
Cause
The domain name specified in the browser does not match the domain name in the following lines in the ArcIMSParam.js file:
var imsURL = 'http://true/servlet/com.esri.esrimap.Esrimap?ServiceName=SanFrancisco';
var imsOVURL = 'http://true/servlet/com.esri.esrimap.Esrimap?ServiceName=SanFrancisco';
For example, if a user accesses the web site using http://204.225.113.3/website/sanFran, they will get a "Permission Denied" error.
There are three possible solutions.
Solution or Workaround
  • Option 1: The best solution is to use a variable that stores the hostname and uses it in the imsURL and imsOVURL variables. The ArcIMSParam.js file already traps this value; it's stored in a variable called hostName; thus, you can make the following change in the ArcIMSParam.js:
    var imsURL = 'http://' + hostName + '/servlet/com.esri.esrimap.Esrimap?ServiceName=SanFrancisco';
    var imsOVURL = 'http://' + hostName + '/servlet/com.esri.esrimap.Esrimap?ServiceName=SanFrancisco';
    This solution will allow the user to access the site using the hostname, domain or the IP without having to specifically hard code the imsURL and imsOVURL variables.
  • Option 2: Change the lines in the ArcIMSParam.js file to use the IP address. For example:
    To access the site:
    var imsURL = 'http://204.225.113.3/servlet/com.esri.esrimap.Esrimap?ServiceName=SanFrancisco';
    var imsOVURL = 'http://204.225.113.3/servlet/com.esri.esrimap.Esrimap?ServiceName=SanFrancisco';
  • Option 3: Use a URL that specifies the hostname rather than the IP address, for example, http://true/website/sanFran.
Article ID:000002457
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
