ERROR
{path to executable file}" does not contain a valid path
Error Message
ArcView returns this error when running an Avenue script that contains the System.Execute request:"{path to executable file}" does not contain a valid path
Cause
This error is caused by sending an argument to the application from the System.Execute request encased in an extra set of double quotes. For example:
arg1 = "c:\temp\test.exe /0"
arg2 = arg1.quote
System.Execute(arg2)
Solution or Workaround
  • Option 1: Remove the '0' argument:
    Code:
    arg1 = "c:\temp\test.exe"
    arg2 = arg1.quote
  • Option 2: Remove the extra quotes:
    Code:
    System.Execute(arg1)
    Change the path in the sample to the actual path of an executable that resides on your computer.
Article ID:000002515
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
