ERROR
Parsing of table has failed
Error Message
In Insights for ArcGIS 3.4, loading a CSV file that contains special characters in a text field (for example, a backslash or quotation mark) causes an error.
Solution or Workaround
If an error occurs when loading a CSV file, try removing special characters or saving the file as an Excel workbook, and reloading the dataset. You must delete the failed dataset from Insights before a file can be reloaded with the same name.
Article ID:000022069
Software:
  • ArcGIS Insights 3 4
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
