ERROR
Parser error: syntax error
Error Message
Attempting to access an item in EditTools produces this error:
"Parser error: syntax error
Program variable parse syntax error
An error has occurred in routine: edit (EDIT_FAT.AML)."
A similar error occurs when accessing the same item with DEFINE in INFO or Tables, ALTER in Tables, or with a cursor in any of the ArcInfo modules.
Cause
The item is improperly named. It may contain one of the following character strings:
._
_.
#_
_#
For example, an item named SUPPLIER._LOC will return the above error in EditTools.
Solution or Workaround
Use the ALTER command in Tables to change item names to exclude the problem characters. For example, ALTER the item name SUPPLIER._LOC to SUPPLIERLOC.
Article ID:000002497
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
