ERROR
Ordinal 3255 could not be located in the dynamic link library mfc42d.dll
Error Message
During a MapObjects deployment, an error message similar to the following may be raised:ordinal 3255 could not be located in the dynamic link library mfc42d.dll
Cause
The error occurs when there is a conflict between debug versions of Microsoft's MFC component that is deployed with your MapObjects application. This is a known Microsoft issue with some DLLs.
Solution or Workaround
Microsoft's Knowledge Base document Q190487 provides more information on this or similar errors. Click the link below.
Article ID:000002158
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
