ERROR
ORA-22275: invalid LOB locator specified
Error Message
On all ST_*FromWKB functions on all Oracle 9i platforms, the following error is returned:
Code:
SQL> select dbms_lob.getlength(SDE.ST_AsBinary(SDE.ST_Point('point empty', 1000))) from dual;
ERROR at line 1:
ORA-06512: at "SYS.DBMS_LOB", line 535
Cause
Oracle 9i implementation has a problem dealing with empty geometry. This problem was detected in ArcSDE for Oracle version 9.2.
Solution or Workaround
This is a known issue, but there is currently no workaround.
    Article ID:000010020
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
