ERROR
ORA-20085: Insert Spatial Reference SRID 7 does not match
Error Message
Transforming st_geometry attributes from one spatial reference to another with the st_transform operator when the attribute is spatially indexed fails with the following error:
Code:
ORA-29877: failed in the execution of the ODCIINDEXUPDATE routine
The following example illustrates the complete error stack:
Code:
SDL> UPDATE parcels SET shape = sde.st_transform(shape,7);*
ERROR at line 1:
TB.PARCELS.SHAPE registered Spatial Reference SRID 6
ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 1413
ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 1740
Cause
Executing the st_transform operator against an st_geometry attribute that is indexed fails because the operator is attempting to update the geometry and spatial index with a new spatial reference identifier that does not match the index's current spatial reference identifier.
Solution or Workaround
Drop the spatial index prior to updating the st_geometry attribute.
Drop the spatial index.
Code:
SQL> DROP INDEX parcels_shape_idx;
Index dropped.
Next, execute the transformation using the st_transform operator.
Code:
SQL> UPDATE parcels SET shape = sde.st_transform(shape,5);
Create the spatial index on the attribute.
Article ID:000010422
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
