ERROR
ORA-00933: SQL command not properly ended
Error Message
When working with Oracle spatial layers, the following error is returned:
"Underlying DBMS error[ORA-00933: SQL command not properly ended
::SQL Expression... << SELECT ... WHERE mdsys.sdo_filter(...) = 'TRUE' WHERE ((...))>> ..."
Cause
The Oracle error ORA-00933 can occur with Oracle Spatial layers when:
1. Joining the Oracle Spatial layer to another table,
2. Setting an ArcMap "Definition Query" on an Oracle Spatial table, or
3. Trying to draw or perform spatial searches on the Oracle Spatial layer, such as ArcMap "Identify".
Solution or Workaround
Upgrade to ArcSDE/ArcGIS 8.1 SP1.
    Article ID:000004032
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
