ERROR
When creating an Oracle spatial index on a dataset stored in SDO_Geometry such as in this example:
CREATE INDEX "SPATIAL_EDIT"."A422_IX1" ON "SPATIAL"."POLY" ("SHAPE")
INDEXTYPE IS "MDSYS"."SPATIAL_INDEX"
The following error occurs:
ORA-04036: PGA memory used by the instance exceeds PGA_AGGREGATE_LIMIT
ORA-04036 error occurs when private memory across the instance exceeded the limit specified in the PGA_AGGREGATE_LIMIT initialization parameter.
The largest sessions using Program Global Area (PGA) memory were interrupted to get under the limit.
With spatial data stored in SDO_Geometry, error can occur with very large datasets with features that vary significantly in size.
To avoid the ORA-04036 error and termination of processes:
OR
More details can be found on Oracle's support page (Oracle log-in required)
Article ID: 000029844
Get help from ArcGIS experts
Start chatting now
