ERROR
The Spatial Analyst Interpolate to Raster functions return the following message: "Operation Failed"
The input dataset may contain a Null or Empty geometry. That is, there is a record without a corresponding feature.
Selecting the features that can be seen in the Data View of ArcMap will allow the Interpolate to Raster function to use only those records with a physical feature.
Use the Select Features tool to select all the input features seen in the Data View. Run the Spatial Analyst > Interpolate to Raster function.
Article ID:000007082
Get help from ArcGIS experts
Download the Esri Support App
