ERROR
Opening an existing project file in ArcGIS Pro fails and returns the following error:
Failed to Open Project
Opening the selected ArcGIS project failed. This project was saved using a newer version of ArcGIS Pro <version number>.
In this example:
Since the user is already working in a newer version of Pro, rather than the version in which project was created, the issue appears to be isolated to a single project, This suggests that the associated .aprx (ArcGIS Pro project) file may be corrupted. When attempting to open the project, an additional error may be encountered:
Failed to open project <project name> unable to determine project type.
As the project file appears to be corrupted, one workaround is to export the data from the existing geodatabase and import it into a new .aprx project.
Another workaround is to perform a clean uninstall and then re-install ArcGIS Pro.
Article ID: 000036482
Get help from ArcGIS experts
Start chatting now
