ERROR
Opening the selected ArcGIS project failed. This project was saved using a newer version of ArcGIS Pro:<version number>
Last Published: April 22, 2022
Error Message
Opening an existing project file in ArcGIS Pro failed and returned the following error:
Error:
Opening the selected ArcGIS project failed. This project was saved using a newer version of ArcGIS Pro:<version number>.
Opening the selected ArcGIS project failed error message
Cause
The error message is returned when using ArcGIS Pro version 1.x to open a project file created in ArcGIS Pro version 2.x. This is an expected behavior. Projects (.aprx), project packages (.ppkx), and project templates (.aptx) saved with any version of ArcGIS Pro 1.x can be opened and used by any version of ArcGIS Pro. However, projects saved using ArcGIS Pro 2.x cannot be opened by ArcGIS Pro 1.x.
Solution or Workaround
Upgrade ArcGIS Pro to the latest version. Refer to ArcGIS Pro: Update ArcGIS Pro to do so.
Article ID: 000027560
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 1 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
