ERROR
Error opening feature class. Unable to create object class COM component
First Published: May 5, 2016
Error Message
When previewing a feature class or adding it to a map, one of the following error messages occurs:
“Error opening feature class.
Unable to create object class extension COM component.”
Unable to create object class COM component.”
Cause
In the first case, the feature class or table has a class extension associated that is not installed on the client machine. In the second case, the feature class or table is a custom object whose behavior class is not installed on the client machine.
Solution or Workaround
  • Option 1: Install the necessary class extension or behavior class on the client machine.
  • Option 2: Remove the extension components from the the geodatabase by using one of the following scripts.
Warning:
Before running these scripts make sure to have a backup copy of the geodatabase.
  1. If using C# or VB.NET , follow the steps outlined in the following How To article:
    How to set and remove the class extension for an existing object class
  2. If using VB6 or VBA, follow the steps outlined in the following SDK article:
    Set the class extension for an existing object class
  3. Use IFeatureWorkspaceSchemaEdit.AlterClassExtensionCLSID and IFeatureWorkspaceSchemaEdit.AlterInstanceCLSID to change the class extension and behavior class to classes that are installed on the client machine.
Article ID: 000002980
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
