ERROR
Note: This issue has been fixed in ArcGIS Pro 3.3 and later.
After converting a layer or map document to a KMZ file in ArcMap using the Layer To KML tool, the file cannot be opened in Google Earth, and a parse error regarding mismatched tags is returned:
Error: Open of file "<file name>.kmz" failed: Parse error at line x, column y: mismatched tag
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012862/00N39000003LL24-0EM39000000wdmn.png)
Note: ArcMap is in Mature support and will be retired March 1, 2026. There are no plans for future releases of ArcMap, and it is recommended that you migrate to ArcGIS Pro. See Migrate from ArcMap to ArcGIS Pro for more information.
The issue may be caused, but is not limited to the following:
Use one of the following solutions, depending on the cause.
Article ID: 000012862
Get help from ArcGIS experts
Start chatting now
