ERROR
One or more layers failed to draw: file_name : Shape integrity error
First Published: September 23, 2019
Last Published: September 4, 2025
Error Message
In ArcGIS Desktop, when viewing a feature class from a third-party database system the following error message is returned:
Error:
The error message occurs when adding a feature class to the data frame, which prevents viewing of data.
Cause
This is expected behaviour. From ArcMap 10.6.1 and ArcGIS Pro 2.2 onwards, validating spatial types from third-party database management systems is no longer performed. This is done to improve performance by not fixing the geometry while drawing the feature class.
Solution or Workaround
Choose one of the following methods to resolve.
Create new tables with compatible ArcGIS client apps
  1. Create a new table with an ArcGIS-compatible database client.
  2. Add data from the tables made in an ArcGIS database client version earlier than 10.6.1 to the table made in Step 1 by copying or using the Append tool.
Use the Repair Geometry tool in ArcGIS Pro 2.2 and above
Alternatively, use the Repair Geometry tool in ArcGIS Pro 2.2 onwards to validate and repair the geometry of the feature class.
  1. Sign in to ArcGIS Pro.
  2. Add the feature class from the third-party database management systems.
  3. Run the Repair Geometry tool.
    1. Select Input Features from the drop-down list
    2. Select OGC as the Validation Method.
    3. Click Run.
Article ID: 000021949
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
