ERROR
Object reference not set to an instance of an object
Error Message
Processing a request when using the Microsoft Virtual Earth Search (currently known as Bing search) function in Business Analyst returns the following error:
"Object reference not set to an instance of an object."
Cause
This error occurs when the Analysis Extent is set to 'Whole map extent'.
Solution or Workaround
This procedure describes how to change the Analysis Extent from 'Whole map extent' to 'Current map view'.
  1. Click on the Business Analyst dropdown menu, mouse over 'Set Analysis Extent' and click on 'Sets analysis extent to current map view'.
    [O-Image]
  2. Re-run the Bing search.
Article ID: 000010740
Software:
  • ArcGIS Business Analyst Desktop
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
