ERROR
Not a recognized workspace factory - Automation error - Is not a valid table
Error Message
When executing a batch process in the Table to Geodatabase tool, several errors are produced if the parameters are loaded from a file. The errors are:"Open Workspace: Not a recognized workspace factory.""ATGdb: Automation error. Unspecified error.""ArcToolbox Warning: Is not a valid table."
Cause
The output ArcSDE geodatabase is not currently available and/or the input table no longer exists. An ArcSDE Administrator may have shut-down the server, or network problems may exist.
Solution or Workaround
Make sure the tables, and geodatabase connections, exist in your ArcCatalog or ArcToolbox session before loading the script into the tool.
Article ID:000003100
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
