ERROR
Non-activation-capable daemon activation invoked with non-client-request event type
Error Message
When reviewing the ArcGIS License Manager log file, the following message appears in the log:
"Error: Non-activation-capable daemon activation invoked with non-client-request event type".
Cause
This message refers to a newer technology (Accresso Technology) that the ArcGIS License Manager authors use for license management called 'trusted storage.' ESRI uses certificate-based licensing, which is the older format carried over from the v7.0d License Manager.
Solution or Workaround
This error sometimes appears in the FLEXnet log file. It is benign and should not interfere with the license server's operation. The message can be safely ignored.
    Article ID: 000010162
    Software:
    • ArcMap 9 x
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
